I respectfully disagree. It has absolutely nothing to do with injector size..... but everything to do with what VE number is in that particular cell.
In my example, I used 80 for the VE number on the table.... and if you trim that cell by 10%, it will be exactly 72 after the trim...... it makes no difference whether you have 160# injectors or stock injectors. I also tried to point out the VE table was scaled and you had to figure out what the new number needed to be once you knew how much you want to trim. 10% trim off a 60 cell would be 54 after the trim. If there is any confusion, it is probably better to just tell it to trim by whatever percentage you want if you are uncomfortable with the math.
Bottom line is for the OP.... I'd make sure my timing targets and AFR targets were conservative and keep cutting the fuel back in the VE table in the appropriate cells until that -10% correction went away and it was only pulling 2-3% fuel...... Once I had it close to zero correction, I'd look at the table overall and smooth out the cells beside the cells you just tweaked.
