DailyDrifter
The Slow and the Curious
- Dec 5, 2007
I've heard before that if the IAC is not connected to the XFI during KOEO it fries the driver. Well I had this happen before I knew about it . So I called FAST today and asked the guy if this is true. The guy said that it's OK unless you plug the IAC in while the ignition is turned ON. I also asked him how much it would cost if the driver got messed up and he said it was around $50. So to be on the safe side i'm going to send mine in and have it checked out. Just figured I let you guys know what I found out.
