Feb 22, 2009 #1 A asloan5 Corn Fed alcoholic Joined May 22, 2007 Messages 386 which dash number do you use for logging or do you create your own with specific fields ie water temp, rpm, tps etc. etc ? or another way to ask same question which fields are important for tuning and which ones are not ?
Feb 22, 2009 #2 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 When a customer orders an XFI from us, I preprogram Dash #8 (Dash for Logging #1) with the following sensors: Actual A/F O2 Corr (%) Inj. DC (%) Battery (V) Spark (*BTDC) TPS (%) RPM Air Temp (*F) MAP (kPA) MAP (PSIA) Coolant (*F) Target A/F PA Enable
Feb 22, 2009 #3 A asloan5 Corn Fed alcoholic Joined May 22, 2007 Messages 386 I am your customer, I did see that option on the menu but I did not realize that you put that there. I assumed it was there from fast. Thankyou
