XFI PA Ramp Retard Table
novi2000
I would like to use the PA Ramp retard table so that once I release the trans brake the PA Ramp Retard table is active. What doI need to wire to the trans brake for this to work. BTW I am going to also wire the internal data logger trigger to the TBrake as well.
Thx.
The "PA ENABLE" wire must stay powered with 12 volts to use this feature.
This is the same wire used to trigger the internal logger,so triggering the logger with your tbrake will not work as you will drop the signal when released.
add a switch to flip after your burnout.
With the said.
go online hit "F6" make sure the "PA Mode Enable" box is checked off
Make sure the "PA Fuel Tables" box is NOT checked off.
and set the activate and deactivate RPMs.
this may seem backwards but its not.
The Deactivate RPMs is a LOW shutoff point(in case you your RPMs drop below),so be sure its lower than the activate or it will not work.
Hope this helps
Thx for your help, my AMS 1000 is on a switch so it sounds like I can use the same switch for PA Enable and the Data Logger.
-Corey
Has any one used the pa ramp retard table for traction control? It seems like it would work really well along with the AMS1000.
