XFI- plug and play- Baileys coil pak- 65lb injectors - rods and misc- alky control kit, RJC downpipe
cartel
everything is one year old- got driven all this summer when nice- motor was new last year from kenny- had a problem with not enough meth and burned one piston 2 weeks ago- the original plan has changed and now were going for 30 psi as opposed to 20 . converting to E85 and changing to COP. so all the existing stuff is for sale. upgrading to crower rods for the 30 psi and selling the scat ones/ (i still have to remove the rods but i believe it was scat originally used but this is to be confirmed. i already have injector dynamics 1700cc ready sitting here to install..
this car is immaculate and can send pics as requested everything will look virtually brand new and everything is well maintained .
baileys full replacement ignition system with magnecor wires- TR6 with coilpak $500 shipped
65lb injectors- offers separately
set of 6 rods- with pistons- one piston needs replacing as broken ring land. - offers
XFI red 2.0 with full tune and plug and play harness from Caspers to place xfi under pass seat - with injectors and o2 sensor - ran flawlessly - i have kennys base tune and a second tune done on chassis dyno here. $2k
RJC racing 3" downpipe $350 _ (the downpipe will be last thing sold after confirming that it wont work with new turbo )
ALky control full buick kit- with spare pump- and buick tester kit $500
complete stock GN AC setup - car has 15000 original miles on it- hoses etc are immaculate- the compressor i may have to reuse if cannot find aftermarket one that fits properly as converting to vintage air setup.
Pics
Would you be willing to sell the alky tester kit separately?
-Patrick-
Picture #3 above shows it on motor as i took it out on weekend..its now in a box. If u cant see it send tel # and il text a pic.
