XFI Package, Adapter Harness, 3-bar Map Sensor, O2 Bung, FREE Start up Program & Tech Support $1850.00 (FREE shipping in US).
Need Injectors? Get 6 (Size 55, 65, 75, or 84 lb) for $345.00 more added to this package!!
Save an additional 10% on these accessory kits with your XFI purchase:
XFI Thumbwheel- 4 programs in one ecu!
Plug and Play Fuel/Oil logging harness Kit.
Custom Driveshaft Sensor Kit that only requires 2 holes be drilled
Turbo Back-Pressure kit that can be mounted in the stock O2 location
Crankcase Vacuum Pump harness for customers with vacuum pumps
Distributor conversion adaptor to allow use of the stock crank sensor
EGT Logging Kit which can record turbo outlet temperature and trans temperature.
Authorized FAST dealer.
Call Holly @ 321-722-1563
