xfi users with 275 60 15 rear tire
northerngn
Master Monkeywrench
what numbers do you have punched in so that the mph in the xfi reads close to actual speed??
hoping someone can go and take a quick look see
-dan
which box?
driveshaft rpm calib
or mph calibration
currently my boxes are
driveshaft rpm 1800
mph 643
stu what are yours?
where does the 610 go
Driveshaft RPM 1800
MPH 610
Hope that helps.
I'm not sure exactly how accurate this was, it just matched the speedo. I should have confirmed it by GPS
i cruised this sat with that setting but still seems off
post back if you can verify setting against a gps
otherwise ill be searching for one of those police flashing mph signs they put in random areas and calibrate against that
-dan
