Is zddp for real, YES, even gm had an additive because they were aware that oils were loosing the ep additive.
If your car has a flat tappet camshaft, then yes it will help.
If you are not using it, the 50,000 miles you put on your car is amplified on the cam, the cam wearing is faster. It is not a magical item, as it takes time to show the effects of not using it.
It is cheap insurance against premature cam wear.
Bill
