I have a Gen II there is an option for the ZO6 MAF can our cars run those? I have a 4" MAF pipe and believe the Zo6 is a 4" MAF.So it wouls be nice to have a 4" all the way threw instead of 3.5" to 4".
I BELIEVE THE Z06 MAF IS A LITTLE SMALLER THAN 4" AND ITS GOT A 5 PIN CONNECTOR IT HAS THE AIT INTEGRATED INTO THE MAF YOU CAN BUY A ADAPTER HARNESS FROM CASPERS TO USE THAT AIT SENSOR:biggrin:
Here's the Z06 MAF on my car. It's 3 3/4", so you'll need a step up adaptor. I needed a 3 to 5 pin connector available from FT to run my Translator...and had to make an adjustment in to make it work correctly.
I swapped mine out to the 4" setup when I changed over to my turbo with the 4" inlet...so I could have 4" throughout. The 02's leaned out a little going to the Z06...so if you're running a fine line...be aware.
