Talked to Damon who has the same 3200 converter. He's seeing 600 rpm drop in the 11.0 range so it's definately odd that your blowing through yours. We'll get yours open and make sure nothings laid over.
This is a rare case but it's not the first time a converter in a 200r application seems out in left field. I have had 2 other instances where the converter looked new on the inside but the stall was off quite a bit from where it should be. I have not been able to find any answers as far as if the converter feed is different or what may cause this. This only seems to be the case with 200r trannies. I have not ran across this with the T-400 stuff.
Dusty, I will be do some WOT passes tonight and check my RPMs for sure with visual and data log info then I will get back to you. Thanks again for taking the time to talk to me on the phone and troubleshoot this. I really appreciate it.
