or so they say.......... im just interested in seeing the long term effects of having this plate in ....no flame intended....just interestedOriginally posted by BLACK6PACK
The powerplate has more flow than your throttle body, so I don't think that caused the problem.
a restriction of air would cause unburnt fuel.....like i said....im interested in the long term effects these plates will have on peoples' motors...there are a lot of people out there who dont post on these boards that dont believe in thes plates....im beggining to wonder myself now........Originally posted by OKTurbo
I think you're barking up the wrong tree. I don't thing the powerplate would cause that much fuel to get in your intake/oil....
Originally posted by Nick Micale
Mike, your comments are right on! No way can the PP restrict air flow as it has more area than the throttle body opening.
It DOES even out flow to the cylinders as Jason's test rig at the Nationals showed to even the most skeptical critic.
His stock-block GN went 9.94 at 134 MPH to show actual,in-use performance. The GSCA project car picked up .2 a sec. and over 2 MPH by the addition of the plate.
Wes, you have a problem and need to find it before you do the same thing to your motor. Unburned fuel sitting in your intake is not a common problem, so even IF there were a restriction, that would not happen.
850 is rich! Fuel isn't going to just sit there on the plate. How would absence of air spin a rod bearing? The power plate restricts air to the back two unlike what you mentioned. If you had any problems with a rich condition you would know it because the car will smoke like a freight train. When I stuck my Max-Effort chip in backwards with 83's in the car it smoked worse than a turbo diesel tractor trying to pull a sled at The Buck! Something was wrong with the engine, not the plate. No flame but why only 12' at 107 MPH with a low 11 second combo like you have in your sig? And 19 PSI at idle hot is fine for oil pressure.Originally posted by Wes
crap intercooler! my scanmaster recorded 0.0 retard and only 850mv ....850 is NOT extremely rich...... like i said ...restriction of air......
i posted a month ago asking if my oil pressure was good at 19psi...i believe even you said that was good!
Originally posted by Intercooler
My point exactly so how is the plate doing anything with your fueling?
Originally posted by Ormand
The power plate will even the air distribution, so that all six cylinders get closer to the same mixture. Cylinders 5 and 6, without the plate, are LEAN. The plate will NOT make them too rich, the O2 sensor reads average, and adjusts pulse width of all injectors. O2 numbers were high, sounds like too much fuel pressure, or stuck injector maybe. The plate won't affect overall loop. Fuel on the cammixture, that's the ECM in closed loop, and fuel pressure, in open ? A restriction in one cylinder might cause unburned fuel in that cylinder, but that's not how the pp works. I'm sure you had a problem, but if you try to blame the power plate for something it clearly can't cause, you'll miss the real cause.
