The following is a (long) story I told a while back on this issue along with pics of my "trap door breather" ! Comments are welcome.
I figured I'd write because I've encountered some very strange oil problems myself. My 87 GN was starting to smoke on deceleration every once in a while (a big cloud)!
After a very intensive 9 month struggle and checking virtually every possibile source for this problem, I finally found it !! For some odd reason, the PCV Valve & Crankcase Ventilation System was allowing this to happen. The system seemed to be operating properly but, if I didn't create a vacuum in the crankcase by blocking off the breather opening, this oil problem persisted !! Here are some particulars : I've owned it since new, oil changed every 3,500 miles, great compression within 5 - 8 lbs. between cylinders, leakdown test showed only 5 - 7 % at BDC, new valve seals, no oil leakage from the turbo (only 10,000 miles on new TE-34), new neoprene front timing cover seal, new intake gaskets (just in case oil was entering into an intake port because of a bad gasket - which it wasn't ! ), and all this on my daily driver with 122,000 miles !! It was not really burning that much oil as I was getting about 1,500 mi. to a quart. This is a bit less than it used to get, but I attributed that to the high mileage. I found out that crankcase pressure or vacuum is very critical, at least on my car, and maybe mileage has a lot to do with it? I was told by a very competent engine builder, that you should not have any pressure in the crankcase what so ever during daily driving. (except under boost conditions of course) My problem never occured under power, even while drag racing ! With a vacuum guage connected to the dipstick, and my regular passenger side breather installed, there were no detectible pressure or vacuum changes happening. With that checked out, I thought I would completely block off the breather opening, and try again. This test showed a vacuum of 4 - 6 in. Hg. while cruising, which leveled off down to 0 in. Hg. when I didn't vary the throttle position. This test under boost produced a pressure of up to 5 - 8 lbs. as long as I stayed into it ! This proceeded to force oil out through the rear main seal and the oil pan gasket, which completely coated the undercarriage of the car !! One thing I did notice with these tests, was my oil/smoke problem disappeared as long as I had the crankcase sealed off !! This was the only way I found to eliminate this smoke! I designed a small trap door on my breather so as to seal the opening under vacuum conditions, and to open up (to vent any pressure) while under boost. This was the best solution all around to retain the original driveability. By the way, I now get about
4000 - 5000 miles to the quart, and with the vacuum almost always in the crankcase, I don't have any signs of oil leaks anywhere ! Best of both worlds !
I know this is long, but I have another story for you. My wife drives a 86 Olds Cutlass Salon ( kissin cousin to a 442), and that car was getting around 5000 - 7000 miles to a quart. ( those Olds V-8 engines are great on oil !) All of a sudden she (my wife) complained that the lifters were ticking on her car. I pulled the dipstick to find no oil on it at all ! I filled it up using 3 qts. and then watched it close for a few days. It was using a quart every 20 miles ! I also noticed her PCV valve was rattling, so I replaced it hoping that was the problem. It helped a little bit bringing it to 200 miles per qt. I then tried putting a 1/8 " restrictor in the 3/8 " hose going to the PCV valve thinking the oil was being sucked up through the PCV system. this actually cured the problem and is back to great oil mileage ! ( this car has 130,000 miles on it )
I guess as the miles pile up on these engines in any car, the pressures that are normal in the crankcase slowly change due to wear and blowby creating these very hard to detect problems ! As long as we're learning something when this happens, I guess it's all worth it !
