owners with a TE-45a combo's and times?
Better be careful getting crazy out on wet roads Scott hate to see a post where you wrapped that 45a around a telephone pole... I have the same turbo an yes it comes on strong as I have the same problems on dry pavement.. The most I have had it @ is 23 lbs an it went a 11:00 @ 124 with a lazy 1.85 60 ft.. An this turbo isn't even getting cranked up till 26-28 lbs..
te-62 to a te45a ???
Adrian87 said:
Is there any way to have my te62 built into a 45a?
Adrian, give john craig a call at Limit Engineering and ask him. He is the one that I bought mine from......
Track time!!!!!!!!!!
Well I went to the track for about 2hrs to see what it would run just for the hell of it. I dropped the wife and two boys out and went up in street trim. 1st pass >reaction .482 , 8:42 @ 90.26mph with a 2.096 60ft with 22lbs boost. this is on radial tires and foot brake. should be better, pro's chime in and give tips.... :biggrin:
i ran at steele ala today and ran a 10.58 with a 1.57 60'. i was hoping to get a better 60'
Nice Times Fellas!
This past Friday I went to the 1/8 mile track and ran the time in my signature. I plan on going to the 1/4 next week, so I'll turn up the wick and see what it will really do. Just for mph due to me not having a roll bar....But the last pass befor going home I'll give it hell and see how deep in the 10's it will really go :wink:
Raymond Bunch said:
What's your combo Daniel?
stock ported heads,intake,206 flat tappet cam. 72lb injectors. reverse manual 400 with ppc converter. single 340 pump. i need to install my double pumper.
SWEET! :cool: That thing run's damn good, for that combo. Nice.
I watched Daniel run yesterday and he ran several low/mid 10.60's and then topped it off with the 10.58. I think his 1/8th was 6.76 at 104 or something close.
Car runs great, looks great and hauls the mail!
warren, thanks for the compliment. it was nice meeting you.
Most read thread in the turbo section !! Awsome...
TTT, For the most read thread in the turbo section if you post your combo please list as many things as possible for others to compare to... thank you!!!
Best run last year was 10:83 @ 121. I backed it up with a 10:97 @ 119. (29psi)
I was running a TE34 with a bad trans in the 11:70's. @ 115 (29psi)
Combo: stock longblock/cam, unported heads but with big valves/springs. 3.5" DP, DFI, 55's, V2, Jimmy trans with tight 9" 3200. Stock rear/control arms. 27" slick.
Left off the trans brake at 8-10 psi, 1.49-1.51 60'
RPM 5100 to 5600
When on the dyno, the car fell off hard above 5200 and 110 MPH.
