Or it could be a ta60Is this a good turbo can this turbo push me in the tens?
Thats what i was thinking anybody else in this?Or it could be a ta60
I like the rjc motor brace compared to the strap, the strap is def not too healthy for stresses and thingsSo they say.
I have not tried one yet.
But good stable motor mounts are a danged good start to eliminate that strap.
And I've always looked at it and though it couldn't be placed at a worse place to really stress the living bejesus out of things.
I mean - it's hanging off a 3/8" bolt and a 1/4" piece of metal and trying to hold down the entire engine - from the front, on a weird vector.
But people swear by them and keep using them.
Can it be fixed if thats the case?Your Block could be damaged too.
Sent from my LG-P705g using TurboBuick Mobile mobile app
X2 --When you open it up, you'll probably see a copper colored thrust surface and a bad thrust face on the crank.That's how mine was.Sometimes it's just the thrust bearing... Most of the time it's the thrust bearing and the crank's thrust surface.
