Some updates:
Went to the dyno again. Made 622 hp on 27 psi. My old TSM car made 595 on the same dyno using the same correction on about the same boost. After the white car made 595, I went right to the track and ran a 10.1 @ 13X with a 1.55 60' (forget the exact mph.) So, This car will be 100 lbs hevier to be legal so it should at least have a 10.1 This car has 10X better suspension already than my old tsm car too I'm still fighting a water in the oil issue but I hope to have that kicked in the butt after the last round of fixes. Tomorrow it's getting an alignment then headed to the track for some easy passes.
Hi Kevin,
The white car was a mess. Suspension, Converter slipping 13-14% and many other issues. You have done a real noce job with this car. I expect much better than 10.1@138
Hey kevin, wheels look nice. Im making big progress on my engine. I need to start a thread.
Sent from my Droid
Definately! I dont need much, downpipe, intercooler...and little things
Sent from my Droid
I thought you had to have Telstars to be THS legal??????
Went to the track tonight. The good news is That I believe the water in the oil situation is fixed
Car still needs a lot of work including suspension tweaks, transmission calibrations and a drivers mod (its been a year since I had power...need to get comfortable again.) I didn't make a full pass, but got the car in 3rd gear and it felt nice a clean up there.
KevinB - Car looks killer, looking forward to more updates!
