Time to start the tuning process HELP
only the stock stuff.
nothing else.
I guess I'm cofused. You said it's flying up to 25# of boost? If you're running the stock wastegate, stock solenoid, and ecm boost control this is not possible unless there's a problem somewhere. Either in the boost control plumbing or faulty wastegate, etc.
No wonder the car had so much extra boost the actuator line that connects to the compressor housing was broken. So back to having a boost-less car!!!!
The car still coughs when I go WOT from low RPMs
When does it stop?
When the new owner picks it up!!!!
Anyway I just finished making the OE actuator adjustable I didn't want to stop on the way home so I just led it where it ended up at, which lucky for me was 15-16 PSI.
But with out touching u a nothing else on the car now my RPMS are crazy high. I pulled over just to see if they drop, it took about 15 minutes of 1700 RPM or better before it finally dropped.
So what would cause the RPMs to stay that high for that long?
A massive vacuum leak. What got left disconnected?
may be :confused:
but i didn't touch anything else at all
it felt like the computer going up and down.
i am going back in a few i'll check for leaks.
BTW the work was done ON the car i didn't remove the actuator for the mod
The IAC valve's plug was half way out.:mad:
The retainer clip is broken. Can you say “wire tie”
But since I opened the hood I wonder what’s going to mess up now.:confused:
Back to the sputter scenario
The car is warm and idleling normal at 700-750.
If I SLAM on the gas the car will pop and sputter.:mad:
BUT
If I ease into WOT it goes smooth as silk.
What should I start checking for the tenth time?
BUT
Sounds like your chip might need some more aggresive AE (acceleration enrichment).
How do I change that?
Chip settings?
Or
New chip?
It did get a little better when I lowered the FP down to 40psi. Vacuum disconnected
Tomorrow I will try to lower the fuel pressure a little more to see how it goes.
Back to the sputter/back fire scenario
And in parking OR in gear
If I SLAM on the gas the car will pop and sputter/back fire.
BUT
If I ease into WOT in parking OR in gear it goes smooth as silk."
I have lowered the fuel pressure to 38 PSI VACUUM LINE DISCONNECTED
And raised it to 50 psi VACUUM LINE DISCONNECTED and that lower RPM WOT sputter/back fire is still around and kicking my ass.
What do I check for the tenth time? Timing?
i found the problem yesterday it was a real shocker to me.:eek:
today i will verify the Cam sensor position AGAIN and EVERY thing else then i will cause the backfire/sputter then fix it again just verify my findings after this is done i will post what is/was the problem.
should be late tonight because TODAY i belong to the wife and kids not the car.:biggrin:
Check the torque on your knock sensor. 14 lbft. no more no less. no tape on the threads.
At idle 800 RPM
O2 are at 880-898
BL is at 138
Everything else is good
What should be my next move to get these in line?
At idle 800 RPM
O2 are at 880-898
BL is at 138
I'm trying to figure out how you can have O2 volts that high and only see 138 BLM values?????
What scan tool is seeing these numbers?
I'm missing something then. :confused:
You can't have those BLM values and be showing O2 near 900. :eek:
