Originally posted by Razor
but exactly how does one know for sure the injectors are at 100 percent..I know Direct scan does a computation to calculate this with values it recieves from various sensors.but what is the formula for this determination..
If load is at 254 and Maf is pegged at 255 ...what other parameter is involved in the correllation to the injectors being static..
And finallyHow is an AFR calculated on direct scan..and how accurrate is it?
Time available vs PW, tell you duty cycle. The ecm calculates a PW, DS compares that to time available, and bingo Duty Cycle.
I've hooked a dwell meter in series with an injector, and the reported figures all line up within a few %.
An injector going static is about not having enough time to shut off and turn back on again. If you build an ecm bench and hook an injector up to it, you can plan as day hear it when it stops cycling, and also when it chatters.
DS doesn't calculate the AFR it displays, it just reports what the ecm has stored as a it's COMMANDED AFR. As long as the info into the ecm is accurate then the data out is accurate. Peg the MAF and then the MAF numbers are bogus, and so are the Commanded AFRs. Also, removing screens, changing air filters all will skew the MAF. As designed it's right, as folks modify things then the greater the error.
The ecm uses a part of the processor as a scratch pad, just writting values down for future use, DS accesses those areas and reports the values. The DC, Tor, HP and Accleration are DS functions, and not related to what the ecm is thinking about.
