01 Regal LS Supercharged upgrades and deletions
I finally got some tuning done with HP Tuners a few weeks ago and to my surprise the car was only at 16 degrees of timing. I thought the guy had set it around 18. The car ran a best of 8.03 @ 86mph in the 1/8 with a 1.80 sixty ft on 14lbs of boost.
A little retuning and we are at 21 degrees below 5700 rpm where it drops to 19 degrees. There was a little knock up top but that was after 3-4 pulls on a warm day with no IC.
Now I am having a IC installed and will be retuning soon should be able to get 22 degrees across the board. Will drop to a 2.8 pulley as well.
Expecting mid 7's in the 1/8 mile. Will report back with a time slip soon. LoL
Which intercooler are you using? Can you post some install pics? I’m about to get started on mine.
Bought it used but it's from ZZP. I'll post up some pics later...
I think most of you guys know what a Stage 2 scoop looks like on the 70-72 GS' we may be finding out what it looks like on a 01 Regal? LoL
Getting this IC installed it looks like it's going to be to tall? It's going to be close. I know there are some cradle changes for the 97-98 cars but it was suppose to clear on this car.
The one on my son's 00 GS sets much lower and it's the same IC.
This is a L32 from a 07 GTP. In a 01 LS. But if we have to cut the hood so be it I don't care.
If the scoop will cover the open spot it might be pretty cool?
If not maybe a cowl induction scoop maybe we'll see.
Did you pull the ABS fuse at the track? My friend had problems launching his GS until I told him to pull the fuse.
Mine has been disabled on the silver car don't have to jack with the fuse anymore.
I finally got the IC done on the silver LS don't have pics yet but I do have a couple of pics of what the Stage 2 scoop will look like. I will be painting it silver. Since its not going to be for cold air which direction do you think?
