How long will a o2 sensor last if i am running 110 cam 2 ,i have not ran pump gas in my car for about 60 miles.should i get a code when they go bad or will i not know.This could be some of my problems.
I had your same problem and had a brand new O2 but it was a 11 dollar cheapie...car had about 1000mi. on it after rebuild...bought one for 20 bucks and cleaned right up. Also showed up as a code on my scan tool. As a matter of fact still getting TPS sensor code..too high voltage and too low. That has to be set right. I did replace my IAC also.
Originally posted by crazygn How long will a o2 sensor last if i am running 110 cam 2 ,i have not ran pump gas in my car for about 60 miles.should i get a code when they go bad or will i not know.This could be some of my problems.
Hey Kevin
02 can be bad and not code. Usually they will code.
Why it's handy to have a scan tool. When they go bad they show slow crosscounts.
Becomes noticeable at 1/2 to full throttle.
Only way to be sure is slap another one in there and see.
