o2 sensors
Yeah, after reading a few of the posts on this web site, I am wondering about my car too! I have a k&n air filter, flowmaster muffler, 2.5" exhaust , test pipe, red 93 chip, adjustable wastegate with boost up to aproximatly 19 lbs. 103 unleaded, to do the 13.3. Traction has been a real problem. I just mounted hoosier slicks for this Wednesday. I am hoping for a big gain from the tires.
I will be getting my sub frame connectors installed this week. I also ordered LT-1 valve springs that I will try to get installed this week. I also plan to vent the engine with valve cover breathers soon. I still need to block the throttle body lines, and install a trans. cooler also.
Next will be the torque converter lock up switch you told me about Mike. I noticed on your recipe that you also had a bleeder valve. Is that valve to relieve built up boost in the engine after you let off the gas?
The last thing I need befor race gas is a scan Master. Then I will try to make the low numbers like the rest of the group. Thanks for all the info. I hope it works on my car. ttanut.
