I don't think the head gasket problems are a result of fastener weakness... it's due to a lack of fasteners around the cylinder and blocks with thin decks.
I have seen a car with 1/2" studs that can't keep a gasket sealed. Nothing wrong with the stock size imo
We done it back in the Buick days and can say it DOES make a huge difference.
Head gasket issues are two fold issue, main issue is the bolt strength. The other issue is lower deck deflection in the head, typically this is the lesser of the two issues.
Now that we started to play with Mustangs they have a similar problem when you push a certain HP level, specially seeing our blocks don't have the extra head bolts like a Stage II motor. That is why we always increase the size of the head bolts and look for an aftermarket head that has the thickest lower deck. These two tricks with Cometic gaskets is a great solution, in fact since we made this change we never had another head gasket issue with a Buick or Mustang.
With that I have to ask the question regarding Melissa's car, I remember back when she ran this time with her car. I was amazed!
Because of this topic and knowing the performance level of this car, I have to ask what gaskets are on this motor, which heads, and how often do you run these numbers with this combination?
BTW, hope eveyone has a Nice Thanksgiving!
