darkred87T
Hi, I recently upgraded to Champion P&P heads and 206/206 roller cam. I had the car at the track last weekend and ran an 11.8@112MPH on pump gas and alky. The alky PAC knob was only turned 1/4 past off. My EGT's were low 1500's, WBAF was high 10:1/low11:1 and boost was 22-23 lbs.
I was driving around tonight and recorded a quick 0-60 run with 93 and no alky. My EGT was mid-high 1500's (a little higher), NBAF was high 700-low 800's and WBAF was high11:1/low 12:1.
My question is, is this normal? It looks like I'm running a pretty agressive tune for just 93 but it doesn't seem to be causing any (real) knock. Should I try making a pass with only 93? I can't get any more boost out my turbo so turning up the boost isn't an option.
I have both runs recorded on Power Logger. If anyonme wants to take a look, I can post the link.
Thanks,
Mike
Thanks,
Mike
