TT/Ameasap
The White Blur
- Jan 31, 2002
Im pretty sure I need to go to another brand, but what #'s do I look at for 1 step colder than my current R42LTS plugs?
SignUp Now!Steve,
My timing mark is 1/4 up on the strap (running 93/alky). I am also getting pre ignition brown specs on the porcelain. Is there another plug that is one heat range cooler that you know of?
TTA needs the longer 14mm thread .7" reachWhat about the ar133 and 132? Or we talking about aluminum heads here?
Bought AR3932(all the store had) and they don't thread in the TTA head. Now what?
Edit:
The shoulder at the base of the plug contacts the heads counter bore.
buickGN3:16 said:is it really necessary to do a plug change for street & race? I mean would it benefit the cars e.t? Im around 17lbs on the 93 pump gas & i use a eric marshall race chip burned for 22-25 psi & 108 octane, but i use 110 octane.
I run the tr5 in my tta. Gap at 30.Bought AR3932(all the store had) and they don't thread in the TTA head. Now what?
Edit:
