Well I Fianally got my cam bearings in thanks to Chuck....Thanks Chuck!
I get home and clean my block up real good and start to install my main bearings....I get the mains in the block and all is good....I start to install the bearings in the caps and when I got to the rear cap I hit a snag. In the rear cap the locating notch that holds the bearing in place is slightly off center......well I had never noticed this before, I noticed it because the locating notch in the rest of the main caps is dead center and those bearings went in great. When I put the bearing in the rear cap the bearings locating notch is center and the cap is not making the bearing not sit correctly in the cap.
I called Summit and tried to explain the issue......the part number for the bearing set is correct and thats all the guy on the phone could tell me, I tried to explain that only one half of a bearing was incorrect.....I am thinking it got packaged wrong from King.
I have the old set of King bearings I took out of the engine and the cap bearing does have a different part#.....it is the same as the rest but has a 1 at the end.
Has anyone else recently purchased King bearings? Any problems?
