10 lbs of boost
streetknights said:
can't get my boost to go past ten pounds???? help
How are you verifying boost? Stock boost gauge (lights) in the dash?
stock actuator(adjustable), i have an autometer vac/boost gauge, i can bypass the solenoid and rig it up "tuner style" and i still get 10
Leak in intercooler?
I found 3 on mine made a tester out of a pressure gauge and block and used my compressor and found them.
10lb Of Boost
Did you check the driver side header? If it was leaking it would be hard to spool up the turbo and build boost.
thanks
thanks tampa, the car sat for about three months waiting on paint, so maybe my intercooler rotted out while it was there
i'll check that header too, i know it has a small leak, but the car was boosting with it leaking before, so i kind of shrugged it off, quess i'll fix it now
