10 second 82' olds cutlass grand national powered
84gnolds
1982 olds cutlass
built 3.8 turbo 109 block
40 over je pistons(plascermic rings),K1 rods,steel crank,comp cams custom cam, harland sharp roller rockers,cometic head gaskets,double roller chain,percision ported heads/intake, bhj sfi balancer,j/w flexplate, steel mains,arp main studs,head studs,70mm tb,83lb injectors,8an braided lines
headers,3" downpipe,PT70 turbo, deltagate wastegate 3" single exhaust
th350 trans 10" coan convertor b/m cooler and braided lines,4" driveshaft,9" rear 3.50 gear 33 spline axles,spool,ladder bar, nodular case, saftey loop,coil overs
translater plus,ls1 mass air, extreme race chip msd dis4 w/interface
lm1 wide band,scanmaster, 2 step
linelike,tublar front control arms, sloted rotors comp eng shocks
adjustable regulator,A-1000 pump/filter 8an line 10 gal cell
car has beautiful int and ext new paint white with pearl 8 point cage dual belts, kirky alm seats
to much to list have alot of paper work and info
clean and runs strong fresh fluids and tires
located in Lanc,PA pics avalible
ford4me0384@yahoo.com
14,500 just like he was asking worth every penny, car is all he said is was runs very very good have had lots of coments on car taken to show and driven never raced at track just figured i would put it on here and give anyone a chance to buy it that did have one before. nothing wrong with it,picures dont do justace.
