109 block weber SG1 NA .20 OVER
Toby_Goodmk
Test Fit officianto
I had this block with my wiseco setup before it got a couple scores in the number 1 and 5 cylinders. The scores would be removed with a honing or definitely removed being bored .030. The only reason I am selling the block is the Pistons I use are .020 new and do not want to buy new pistons. I have 2 other 109 blocks at my disposal so I am starting fresh. The block was align bored perfectly and the main bearings showed no wear at teardown. This SG1 has the oil drain hole drilled and tapped already.
I would like to get 350 out of the block. I can send anywhere in usa.
im in dayton can pick up if not sold &maincaps/bolts inc.Going to the game tomorrow and could pick up or I work in WC
