109 short block
gmpower6
Fresh
.030 trw pistons
standard turbo crank
New GM front cover
New GM crank sensor
Stock rods,with stock bolts
Stock main caps
Clevite Bearings
Double roller t-chain
New oil pump with thrust plate
Cam shaft is a 204-214 with gm lifters
New Gm cam sensor
This is a nice piece. Looking for $1800 OBO
Thanks Sean
Who did the build?
and am I correct to assume fresh means NO miles?
Assembly required?
May need to pick this one up soon!
who did the machine work & who assembled it interested but need to know these things. as I would have to get the rod bolts changed out and a support installed at a min. Thanks
