10's with Alky control kit and single 340?
Steve
I am putting my WE4 together and I am curious if a single 340(hotwired of course) is enough to run high 10's with alcohol. My car is set up very similar to my last T-Type that ran 10.60's on race gas and no alky. I had a double pumper in that car but I would like to know how much of the total fuel load the alky will make up. Is 10.80/10.90's too much to ask of a single 340 and alky? Thanks
Back in 94 I ran 10.70 @ 125mph with just a Walbro 340 intank pump, so I would say that it should not be a problem when mixed with Alky.
I run a single 6 year old 307... times in sig
Non-issue.
Insane6, you and I have have a very similar combonation and I hope mine runs like yours. I saw in your post that you now have a dual nozzle set up so I assume you had a standard single nozzle system before? Razor, are you running a dual nozzle system also? Thanks
Steve
Steve
Yes. Once you can hit 100 in the 1/8, or 125 in the 1/4.. I step up the nozzles on my system.
