11's on the pump
Our's is not exactly a stock engine or stock heads or a TTA but it is a F-Body
86 Camaro, TTA front mount (CAS) JE pistons,Stock rods,crank,block@.30,Comp cams 218,out of the box GN1heads,stock intake&Plenum, .70mmTB,.72mm turbo,stock headers(GN) Fast System w/72lb/hr inj on 93 pump gas through the mufflers on ET Streets *with smoked trans* about a 3/4 pass at Mid Mich motorplex at the the First FAST Event last fall.
60" was 1.51 leaving with 3lbs boost
11.31@117mph with 14lbs/boost.
It was about 55deg out that day so I'm sure that helped.
I think I was in a gear even though the RPM's just hung around 5900 after 1st . I realy never felt it shift. The fluid smelt like burnt dog hair
Lance pointed out that we needed to move the FP regulator and lines around because we were leaning out on the passenger side bank. We also needed to move the air temp sensor into the plenum and a few other little items.
Thanks agian Lanc and Craig Hope there are more events this year!
