Slowing this thing down, no real racing around here. I just traded for a baby turbo and will be building a new short block,maybe. I have a small roller 206/206 that i will be using and will use good pistons. Will I need steel caps? Just bought a motor that could go in as is and it is not capped. I have a PTE stock location, FAST, PTC converter and built trans. Good stock ported heads.Turbo is a PT54.If I don't need to pull this new block I just got apart to have it capped it would be nice. I will if you all think i should.
