SignUp Now!petesgn said:I just installed these brakes from a 2000 s10 blazer 2wd they were 99% bolt on.
Man they stop way better than stock and i can run my T wheels with out any rubbing.
bruce said:That's great having another option....
Did you have to use an adapter plate, and who made it?.
WOOSHH said:What do you need off of the Blazer?
WOOSHH said:Thanks-this is better than the Baer 11in system.This caliper looks very similar to the C5 Corvette caliper. Do you think it will clear with a 87 GN rim?
WOOSHH said:Let me know when you get a chance to see if the GN wheel clears. Thanks again.
Gbodynutt said:How's the braking? Did you have to add an adjustable proportioning valve or does it seem to work pretty good without one?
petesgn said:No plates or adapters Well the only adapter i used was a edelmann 3/16 to 1/4 inverted flare for the brake line thats it .
Only 98 -05 s10 blazers come with this brake setup
i just unbolted spindle assy from the donor blazer purchased the line adapter bled the brakes and off the alignment shop..
