Thanks for the response, Vader!!!
What are your IAC counts at hot idle?
Between 18-25
How do your plugs look?
Replaced them about 50 miles ago.
Ohm test all your plug wires and ohm test the coils. Front to back...should be around 11k to 14k ohms. The plug wires should all be fairly close to each other.
Coil pack is new AC/Delco and all tested around 12.5K. But I have not checked the plug wires.
How do your o2 crosscounts look? Are they cycling from 0 to 255 within 90 seconds?
THAT is a good question!
Check the counts for IAC and o2's after the engine is warmed up AND its running in closed loop.
Doesn't my Turbo Tweak chip run in Open Loop at idle? They tend to be pretty high-in the 800's.
Also, this is a big one that everyone should do. Get a 1/2" to 3/4" heater hose, and listen at the base of each fuel injector and all around the mating surfaces where the intake manifold meets the heads, all around the vacuum block and any other hose connections you can access. A mechanics stethoscope wont pick up vacuum leaks and the propane test is worthless. A vacuum leak will be VERY audible through the hose.
Now THAT I haven't done!
Check every hose, everywhere, for cracks. Replace as many as you can and hose clamp everything you can. Make sure all the hose clamps after the MAF are tight and the silicone tubes are in good shape.
Just did that when I replaced the plugs.
Pop the PCV valve out and shake it to make sure the flapper is free and flush it out with alky in both directions.
Did that with the plugs as well.
Adjust/set all the sensors.
Checked when I replaced the plugs. Trust me, they're spot-on.
Just for kicks, pop the #1 plug out and rotate the motor till air starts pushing out pretty hard (compression stroke). Pop the cam sensor cap off and make sure the window on the brass colored ring is facing somewhere toward the air filter.
Haven't done THAT yet!
Look at the back of the passenger side head and make sure the ground wires are clamped down well. You can see it best from under the car.
I have a large master ground on the firewall up high near the coil pack area.
Very clean and neat.
Even though your issue is probably 1 or 2 things, doing all of the above will make the car run even better and give you peace of mind.
