Mar 20, 2011 #1 9 9SECVSIX Member Joined May 25, 2001 Messages 520 Can someone suggest a good 12mm plug for the "R" heads. Street motor with Alky, use to use Autolite 104. Thanks 9sec.
Mar 20, 2011 #3 vacuum 6 Well-Known Member Joined Jan 6, 2006 Messages 2,401 Why you want to change? I like the 104s over 103s.
Mar 20, 2011 #4 9 9SECVSIX Member Joined May 25, 2001 Messages 520 vacuum 6 said: Why you want to change? I like the 104s over 103s. Click to expand... I guess I didn't make myself clear...I use to use 104's in the 14mm plugs. I didn't know a 104 was avaiable in a 12mm plug. Are you aware that late GN1 "R" heads use a 12mm plug not a 14mm? thanks 9sec.
Mar 20, 2011 #5 L larry33kc Well-Known Member Joined Aug 19, 2001 Messages 1,714 Search in my post. I asked this awhile back but cant remember what they where and I am not at home to look
Mar 23, 2011 #6 9 9SECVSIX Member Joined May 25, 2001 Messages 520 Sounds like our only option is the AR 4132 .I suspect it's a bitter cold racing plug Thanks for the reply larry.
Mar 23, 2011 #7 L larry33kc Well-Known Member Joined Aug 19, 2001 Messages 1,714 Hey no problem, its funny I just brought a plug up to tell you the # but you beat me to it. That plug is what was recomended by Champion.
Mar 23, 2011 #8 9 9SECVSIX Member Joined May 25, 2001 Messages 520 larry33kc said: Hey no problem, its funny I just brought a plug up to tell you the # but you beat me to it. That plug is what was recomended by Champion. Click to expand... Do you consider that plug OK for a street car running 91 and Alky? Thanks
Mar 24, 2011 #9 L larry33kc Well-Known Member Joined Aug 19, 2001 Messages 1,714 Don't have enough time in it to give an opinon
