No where to go? How about then add cam, heads, headers, etc.
I'm scared to open my stock block. I see people having nothing but problems after they go messing around with it. I'd rather first try simple bolt ons and big boost. It works.
If you want to make "x" amount of power, It would be the same cylinder pressures and fuel, and air, either blow it in with big boost, or tear apart motor and replace heads, intake, etc. same/same. I see no extra danger compairing big boost/stock heads and normal boost ported heads. Explain what you think and why. Given the fact that you need a big turbo either way, and the correct fuel, etc. I think just both are just as safe/dangerous. Power is power....the more power the more danger, and of course knock is worse the more power you are making
