.125 thickness intake gaskets?
jns
Where can I get these thick gaskets from? I'm having trouble sealing up my intake to the head. I read a while back about someone using these and he said it fixed the sealing issue. Thanks!
Thanks! My only problem now is that it says "Must use with Aluminum heads". Mine has stock heads. Or does it mean....Aluminum heads require these or can be used with stock heads:confused:
I am using them on aluminum heads but don't see why they wouldn't work on iron. Give TA a call and ask to be sure.
