1500+hp stage 2 Buick V6
EightSecV6
MDBL
Ok, here goes again.
-Stage2 on Center V6
-Crower billet crank,Carrillo rods,Ross Pistons
-Comp custom roller with Isky lifters and rev kit
-The best S2 heads you will find with titanium valves and all titanium hardware ,Jesel rocker system
-S2 tunnel ram intake manifold with 160pph inj and 90mm throttle body and dual SX regulators
-Moroso dry sump oil pan and BMS front cover
-MSD crank trigger, MSD distributor, BHJ balancer and JW flywheel
-MSD plug wires, 7AL2 ignition box, Pro power coil.
-FAST seq unit with indiv cyl control and custom fuel/timing launch control,complete FAST engine wiring harness
-FRESH Moroso 4 stage dry sump pump and 200A alternator mounted to a .250 motor plate (bolts where stock water pump would to mount engine)
-Custom stainless forward facing headers with Y pipe x-over and PT98 turbocharger
-Meziere billet, remote mounted water pump
-Weldon 2035 fuel pump
-Stefs dry sump tank with ALL plumbing
This engine ran 7.25 at 188mph in my 2570# Grand National. We can provide installation and fabrication to get you going. ABSOLUTELY the best you can get. The engine is completely fresh from top to bottom.
EVERYTHING listed above for $23,500
ahhhh
before you start that, make sure no little kids are sleeping in that compressor housing! they probably use it like a hammock :eek:
Hey turboelky if i buy the motor can i and all my cars stay at your house after i get out of the hospital when the wife finds out. :eek: I know your wife likes atleast two of my cars. :biggrin:
yeah
Lulu needs a boyfriend :D that motor makes me want to puke, it would probably twist my car in half. Good luck again on the sale 8secv6! that will make somebody proud.... or scared senseless :eek:
does that thing suck in small cars when cruisin down the street? I cant imagine what sort of driveshaft one has to use on a car like that. Hows the gas mileage? lol
This is a great deal, if I had the extra money it would be in NC by now :eek:
Wow, did you get a look at that turbo?!
If you look real close you can see a decal by the turbo that reads "Keep small animals at least 6 feet from turbo" maybe it should say children too!
TTT you've got all winter to put this thing in a car, come out in the spring and beat everyone!
Hey bill can you send me the winning #'s for the california lotto so i can justify the purchase:D that is one awesome setup and whoever gets that beast is going to be one lucky sob!:eek:
Bill,
What are the Carillo Rods rated at?
They are the best billet rods Carrillo makes, with CARR bolts bought new before the engine was fired. Carrillo doesnt give a HP rating on them. Some builders prefer I beam, some prefer H beam, both styles have broken when stretched beyond reasonable limits or punished with unreasonable tuning.
Thanks for the information, I appreciate your time.
Good luck with the sale and TTA! =)
This post calls to me in my sleep.... Anyone want to buy a kidney? :D
