15x10...5.5 bs will it fit ?
hang10
old surfboards wanted!!!
Draglite, 275/60/15 tire, without notching the frame.....wheel spacer with longer studs ? Able to pick up a pair locally for a good price... thanks !
Mmmm...I'd say it's too much rear spacing!...I have some 15"x10's with 275-60-15's. The rear spacing of the wheels is 4.50" and although it fits real nice, I think it's the most rear spacing you can use! Anything more than that and you're very likely to have some tire/frame rubbing issues, unless you decide to notch it.
Claude. :smile:
My steet tires are 275 60 15 drag radial on 15 x 10 w/ 5" back...... this is the max back space you could have, I get a slight rub on turns or corners.
A 15x10 with 5.5bs with no spacers puts the rim bead about 1/8" away from the frame. 5" would be the max bs.
