I honestly don't know where I had heard that. I think it was the manager of our local track? Anyway the way I saw it is that the further out you move the wheel on the studs, the more force you are applying on them, like a lever. If you picture a tree branch-if you grab it at the base & hang on it it will support you, Now go out further & the same weight will put more force on it. The further you go the more force you will put on it. Go far enough it will bend or break. I don't mean to start anything here I was just posting my own experience here in hopes to help others not have the same problems. In my situation I was running 1/2" moser studs 3" long, with 1/2" thick billet aluminum spacers. The holes in the spacers were just over 1/2" so they slid on nice & snug. I ran two different style wheels with this setup. One was the stock gta wheels with the tapered seat lug nuts, the other was a centerline style with a shank style lug nut. I do not know which wheel style did it but I ended up with 10 bent wheelstuds, all bent backwards as from hard launching. I never even did get it to hook real hard back then either, 1.50 60ft or so.
John Plog
