SignUp Now!I just installed some Street Lites on my GN in 15 x 7 fronts and 15 x10 rears with a rear spacing of 3.5 in. and although I have not driven the car yet, there does not seem to be any issues with them.
Claude.![]()
Do the 15x10s fit under the stock wheel well without notching the frame rails?
Yes they do, but you'll probably have to roll the fender lip...but no frame notch needed.
Claude. :smile:
I'm using some Good Year Eagle GT II's 275-60-15's and the rear spacing on the 15"x10" wheels is 4.25"...see pic below...Very nice,what backspacing did you use for the rears,i have a set of 275/60/15 drag radials i want to use,think they will fit?I dont mind rolling the fenderwells if i can use that rim....
In answer to the backspace on the fronts, use the 1.75-inch setup. Fit is perfect on my T-Type, with a M&H P185-75R15 radial.
'Beard
