15x8.5
gnloyalty877
t'squick6
Can anyone running 15x8.5's post some pics on the car and what backspacing is used. Could i get away with running them without modification to the fender lip? I don't want them sticking out of the fender-well. I'll be running 275/60's
I don't have them on the car yet but the back spacing is 3&5/8" . It was a standard for the westerns and they look like WH1 style. I still have to blast them and then clean them up a little.
what's up Tyler? Chuck here (bought your old TE-44). As long as you stay around 4" bs you should be fine with a 8.5 wheel. Try to get as close as possible to 4". Sometimes 4.5 bs will work depending on the tire. I have 10" centerlines with 275/60/15 standard radials, but i have to use a spacer so tire doesn't rub on inside frame rail. BS on mine is around 5" though. Hope this helps some. (BTW, i noticed you got 1 of the BB turbos now, i bet that car really hauls $*@ now!!!).
