SignUp Now!Does anyone know the backspacing of the 16x8 GTA FRONT wheels? May try M&H 275 55 16 28inch drag radials on my GN but not sure if they rub. All info is appreciated,THANX!
Scot, yes they're close to the frame, but if you want, you can always use a 1 1/2" thick wheel spacer to move the whole wheel outboard and not only it increases the tire-to-frame clearance, but it also gives the car a wider stance which makes the car look much better! See this link: Wheel Adapters SpacersI'm after the same thing! With the same rims!
For this car...
255-50-16's on it now and I can't fit my fingers between the frame and the tire..
Claude, Thanks for the link but it's all japanese to me. lol Which ones would I need?Scot, yes they're close to the frame, but if you want, you can always use a 1 1/2" thick wheel spacer to move the whole wheel outboard and not only it increases the tire-to-frame clearance, but it also gives the car a wider stance which makes the car look much better! See this link: Wheel Adapters Spacers
Claude :smile:
Scot W.
Thank you!Scot, the ones you want are the second ones from the top (Wheel Adapter 5 Lug 4.75" To 5 Lug 4.75" Pair). Click on them and it'll open a new page where you'll be able to chose the thickness you want (in my case they're 1.25" thick), that's all...
Claude
Claude, do you have any pics of your car with the 1.25" spacers? Thanks
Eric
does anyone use the rear GTA wheels?
Looks good Claude, those GTA wheels look 100% better when they're spaced out in back.
