SignUp Now!And you never have to use the high position on the windsheild wipers.
Jeff
The reason an alternator putting out 16volt is considered bad on a 12v battery is that the plates will become corroded and it will also cause excess gassing which causes the cells to loose electrolytes. In simple terms, the battery will wear out prematurely or possibly explode. AGM type batteries require higher currents to fully charge and are more tolerable to higher charging alternators.
It is recommended to upgrade all wiring to a minimum of 16ga when making the switch. I don't see any reason to run a 16v system on a street car unless you are into car audio. I would never go back to a 12v system on my race car. FWIW
If 140 amps meets your max usage requirement, I don't see any reason why it wouldn't work.Any reason why this alternator won't work ?![]()
Delco 16V / 140A Racing Alternator
Powermaster has taken the Delco-Remy CS130 to a new level both in looks and reliability. They offer incredible output both at idle and at highway speed. The housings are custom made and offer a streamlined look for the discerning enthusiast. Made for the street but suitable for racing environments, they are internally regulated and feature both internal and external fans. The diodes, which were a cause of failure in the OE Delco-Remy design, have been upgraded from the OE 25A wafer type to 50A press fit type for maximum durability. The gold battery post is a signature of an authentic Powermaster alternator.
713-478026
Delco Racing Alternator
16 Volt
140 Amp
1-Wire
$171.99
George
713-478026
16 Volt
140 Amp
1-Wire
$171.99
George
Do you NEED 200 amps - NO. You didn't mention if your car still has the Powermaster brake system which is a power hog. Think about it like this - a stock TR has a 120amp alternator so if you don't have AC, radio, Powermaster, etc. but have the addtional load of electric water pump, HP fuel pump, etc. you're about breaking even.
If your car is race only I would either A) don't even run an alternator - simple, less weight, less drag on engine, less bs. OR B) run a 120-140amp alternator which would be plenty with the equipment you described. Remember, amperage is like flow whereas voltage is like pressure. The beauty of the 16v setup is that it will always be ahead of a 12v system even when fully discharged. My race car runs 3 (yes 3) fuel pumps, intercooler pump, water pump, MSD 7AL ignition, XFI, datalogger, transbrake, various timers, relays, etc with a single 16volt AGM battery and NO alternator. Datalogger has never shown voltage fall below 15.5v for the entire time car is running including shutdown - usually maintains about 16-17v during the run. As long as you charge between rounds an alternator is simply not necessary unless your class rules just require it. FWIW.
Thanks a lot Will, much appreciated. No I don't have the Powermaster. I run manual brakes.
I just got my Turbostart 16 volt battery and charger and just ordered a Powermaster 140 amp 16 volt alternator ( listed in post 64 above ) I just wasn't sure if the 140 amp would be enough amps to get the job done. I would have re-done the order if necessary. Yeah, I need the alternator for class requirements presently, but could remove it if required.:biggrin:
Thanks again. See you at Bowling Green.
George
Who went to Europe on business. Brought her 120 volt curling iron with her from the States, borrowed an adapter to plug it into the hotel 220 volt outlet, let it warm up, then burnt the hair off the front of her head. Funny girl.
George,
I run a 106 amp 16V Alt. with no problems. I have 2 electric water pumps, one electric turbo sump pump, and a Weldon, Crane Ign and XFI.
