Ya know, I'm thinking my cam sensor may be 180 out. Every once in a great while, it will give a good backfire instead of starting, especially if I have had the orange wire disconnected prior to starting. The engine has maybe 2500 miles on it since it was rebuilt by the original owner in 1996 and it has always idled like crap since I bought it in '97. I've used the stock chip, an old kenne bell 9006(?), and a Thrasher which remains in it. The thrasher is supposed to have a 'glass smooth' idle, and it's actually better than the other chips, but glass smooth it's not. It idle hunts all over the place, and idles pretty inconsistantly most of the time. Sometimes it idles pretty well, but only sometimes. I've done all the IAC reset, tps set, played w/ the FP, etc, etc. I have no codes, and the scantool numbers are reasonable. It DOES seem to have a pretty noticible tip-in stumble, and is sort of lazy to spool. So my question is this....
What would you guys recommend as the easiest way to VERIFY the cam sensor setting? I'm ASSuming I could get it to #1 TDC, and pop the cap and see where the sensor is positioned? Is there a way to verify #1 TDC on the compression stroke without pulling the valve cover? And which way should the sensor be pointing? I guess if I find it's NOT out by 180, I should go ahead and finish off the setting procedure that gnttype specifies??, as maybe it could still be igniting the correct cyl, but fueling the wrong one? Sorry for the book, sometimes I think as I type...:wink: Thanks in advance, your thoughts will be much appreciated....
