I am interested in selling my 1967 Chevelle Malibu. The car itself is a survivor with and upgraded drivetrain. The car is very solid and straight. The floorpans are in great condition and rust free and everything works like it should. The car has had one repaint in the late 70's/early 80's. The cars runs and drives very nice and is 100% streetable and runs on 91 pump gas. The motor made 612hp on the engine dyno. The motor/trans/converter went 11.40's in a heavier car so should run better in the Malibu. All of the suspension has been rebuilt or replaced with aftermarket. The car does have some minor rust in the normal areas but the car is very solid. I have lots of pics and short walk around video I can email or text upon request. Thanks $15,500 Might trade for a C5
515 BBC(GM 502 block, GM forged crank, GM forged rods, SRP forged pistons)
Merlin Iron rectangular port heads
Edelbrock Vic Jr intake
Carb Shop 1000 cfm 4150 carb
MSD Billet Dist
MSD Blaster SS coil
MSD 6AL2 ign
Comp Hyd roller cam
Built turbo 400(retains automatic operation)
PTC converter
Custom 3.5" nitrous ready driveshaft
12 bolt rear
3.73 gears
Moser 33 spline axles
Moroso posi
TA girdled rear cover
Aftermarket tubular upper and lower rear control arms
Sumped stock tank
Holley HP150 pump
1/2" Push lock fuel line with AN fittings
AFCO aluminum Radiator
Autometer gauages
B&M shifter
SFI Balancer
SFI Flexplate
Milodon 7 QT oil pan
Optima Yellowtop battery
Poly engine and trans mount
MSD Billet Dist
MSD Blaster SS coil
MSD 6AL2 ign
Comp Hyd roller cam
PTC converter
12 bolt rear
3.73 gears
Moroso posi
Sumped stock tank
Holley HP150 pump
Autometer gauages
B&M shifter
SFI Balancer
SFI Flexplate
