TURBOPOWERED68
David
- Jan 31, 2006
Up date 7-6-07
Up date 7-6-07
1968 Chevelle
White
Front disc brakes
Power steering
Power brakes
New
1-ball joints
2-springs (moog)
3-shocks
4-brakes
5-window felts
6-wind shield
7-dash Pad
8-recovered OE seats?
9-A-arm bushings
10-quater panels
11-package tray
12-Body bushings
13-steering gear box
14-Master cylinder
15-Fuel lines- Feed/Return and vapor
16-Front to rear brake line.
Engine
1987 GN
To do the wiring I used a Casper’s "dash mating wire harness"
1-New timing chain set- Edelbrock double roller
2-oil pump
3-Aluminum vacuum block with Brake Booster port.
4-AC delete pulley
5-GN gas tank
6-hot wire fuel pump
7-Rebuilt stock turbo
8-second oil filter dedicated for the Turbo.
The car is not finished yet and these are some things that it might get. And yes these things may affect the price
1-it has an open 10 bolt rear.
I am thinking of putting in a mini spool. Not shore yet
Up date 7-6-07
1968 Chevelle
White
Front disc brakes
Power steering
Power brakes
New
1-ball joints
2-springs (moog)
3-shocks
4-brakes
5-window felts
6-wind shield
7-dash Pad
9-A-arm bushings
10-quater panels
11-package tray
12-Body bushings
14-Master cylinder
Engine
1987 GN
2-oil pump
4-AC delete pulley
5-GN gas tank
