Darkstar72
- Oct 1, 2017
For sale - $20K cash, FIRM
For Trade - 1986 or 1987 Grand Nationals or nicely optioned T Types. Must be clean.
1972 Nova, 383 stroker SBC, 6-71 Hampton blower (3% undersdriven, 6 lbs boost), TH-350 trans with reverse manual valve body and transbrake, 3200 stall converter, 12 bolt rear, 3.73 gears. All engine internals forged (pistons, rods, etc), aluminum heads, big block crank snout, double key ways, solid roller cam, roller rockers - last gone through in 2009 with about 25 track passes and 1500 street miles. Hooker Super Comp headers into 3" exhaust with x-pipe exiting behind rear axle, full exhaust/no dumps. Transmission was gone through at same time engine was out and rear gear changed shortly after. 2" drop spindles in front, rear leafs de-arched 2", 90/10 Calvert shocks up front, standard KYBs in back, cal trac style bars out back. Manual steering, manual brakes with front disc conversion and CPP master cylinder with built in prop valve. Car has been dynoed at 510 HP at the wheel and 515 TQ. I have a binder full of receipts on this car that goes with the car.
Car was brought back from Southern California in late 2008. Floors, trunk, frame solid as can be. Paint is basecoat/clearcoat, Storm Grey Metallic. Paint job presents well, is older with scratches here and there and is not a show car flawless paint job. Full interior, no cage, not a cut up race car. Has bolt in subframe connectors
Text or call me at 630 776 2749.
