1978 - 1987 GM G-Body Lower Control Arm Relocation Brackets
tbirdv6
Reposition your instant center by changing your lower control arm angle for improved traction. After product installed, you will see a great increase in traction by lowering the rearward angle of the lower control arm, allowing more force to be placed on the rear tires. Relocation brackets have two settings to allow the lower control arm to be lowered either 2" or 3", depending on your preference. Settings are placed in a correct pattern that will allow use of all OEM control arms or any aftermarket control arms (brackets do not require a longer control arm). Brackets installed provide a 0.10 or better 60-foot reduction and an increase in track consistency. Brackets are constructed of 0.188" cold rolled 1018 steel, CNC machined for precision tolerances. Relocation brackets will work with all OEM and aftermarket rear ends.
$39+shipping
FRED
turbobuick2@yahoo.com
