Swapped to a 4L80E
I wanted to add to the thread that the 4L80e swap I done on my car is nothing but a compliment to the Turbo Regal's drivability. And ultimately, it's a piece of mind of having a durable transmission in the car. I don't get that feeling anymore that when I go out and run the piss out of the car that it might be the last time the transmission will work. This swap puts it up there in the top three mods I've ever done to my car, and I've owned my car since 1986.
Also, for those who are scared about losing 2 tenths off your time with the extra weight and internal loss.... just make up for it by adding a couple of pounds of boost.
My stock bottom end/212 flat tappet/home ported irons/stock intake/6262 combo trapped 126 mph at 28 psi in 85 degree air with lackluster 60' times and a lot of converter slip through the 1/8 at BG this year. With the latter two issues addressed, I really think there is another mph or two left in it. There are probably hundreds of TR's with basically this exact engine setup running around, and the mph seems about bang on to the average for the tune. I agree, and would raise that it might only take 1 psi to cancel out, lol. No beef with the 4l80 here, it's doing just fine.
Have anyone noticed anything about it stealing HP. after you have driven it for some time now.
I probably have 1000 miles on mine, and it takes a beating. We haven't touched the tune we got from Bob. I like the way it shifts, I'm not sure on power level . BEATAV8 does the tuning. Maybe between 500 and 600 to the tire. I know I didnt need it, but I got a killer deal from CK so in it went. I had an older Jimmys build that he is going to go through and that will go in my limited
Finished my swap before BG and Bailey helped me work the bugs out with his trans tune, all I can say is it shift’s perfectly up and downshifting, no clunking or etc. only at 9lbs of boost on a 7170 and circle d lockup converter.
Which shifter linkage kit do you guys use to connect the factory GN floor shifter to the 4L80e shift lever?
The parts I used are all listed earlier in the thread. But to clarify some things
I used the stock/original shift cable, Shiftworks C351 bracket to hold the cable. Stock shift lever from the original trans, And modified stock parts for the column lock linkage.
You can see the cable attachment here:
TurboBob, you ever gonna offer a complete swap kit and a trans Ecu tune package for future GNs?
It's always nice to have a 1 stop shop and then an initial Ecu trans tune to throw in to get really close fast.
Nice, great service like usual. That trans map alone is a huge plus.
Anyone offer the shifter and all that install easy jazz?
Looks like there's a special dash speedo converter for $770 unless you go DD Efi dash. Ouch
I bought a modified tailshaft housing and gear set to drive the factory speedometer like normal for just about half that. I did end up having to go back in and glue the drive gear onto the collar it rides on, but it has worked fine for over a year now.
I used the same modded tail housing from ebay.. I goofed when I first installed it, the speedo cable core was too long and it jammed inside the driven gear. But once I trimmed it a little it worked great.
There's one on Ebay right now, 7-30-25 for $400, title..
4L80E Tail housing with Mechanical Cable Drive Speedometer Conversion
Is this what you guys used?
Do we need, Full Spline, or O-Ring output shaft?
Just curious since my future might need this stuff since turbos are getting crazy powerful.
Yes, thats what I used. You want to get the one that matches your transmission. Or order the full-spline one and plan to use that style trans or convert one.
Bob
FWIW, if you do find an o ring output shaft, you can discard the metal tube around it and the o ring, and run a regular slip yoke with a counterbore in it. Sonnax makes one, and I believe Spicer does as well. I can't comment on the strength of the outputs vs each other, I'm below the limit regardless.
In case anyone's looking for a lower weight option, the Reid 4L80e apparently weighs 120lbs vs the normal 178lbs, no converter or fluid. Not sure if that's with the bell housing and his tailpiece but a 200-4r weighs the same w/o converter and fluid.
Reid 4L80e is also an updated version that solves some weaknesses and more efficient. Might be an equal swap vs the 200 in weight and drivetrain efficiency, curious.
