This s a "turbo" Buick board. Put a turbo on that thing and maybe someone will talk to you.
Throw a fresh set of intake and head gaskets on that puppy and get her back together. Did you ever do a compresion test while you had it together? You know you've got 27 year old valve springs on those heads. There's a lot of ways you can go, just have to decide what you're doing. If you're goin to run it with a turbo, you don't want a lot of cam, or compression. If you're not, you can look at raising the compresion and bumping the cam and fueling up. MAKE A PLAN.
